Macintosh SE/30 Faint chime and no video, possible short on +5V
Ferrix97
Hello
The Analog board is OK, I used another SE Board to test it and it works fine, I also installed the board in another SE/30 and it still shows the same issue: faint chime and no video (screen is totally black)
This seems to be a very early revision board, with the yellow-band capacitors.
I was looking at UE8 and I noticed that the resistance between +5V and GND is about 56 Ohms, which seems too low.
I then removed the capacitors and washed the board, now the resistance on J12 and UE8 is about 35 Ohms.
Soon I will solder new capacitors on the board, and measure the resistance again.
after washing the board (with the old caps still in place) The board produced a very faint chime, reset and interrupt also worked: I could hear the chime when I press reset and the sad mac tone when I press interrupt.
Once I recap the board, I will connect it to a Floppy drive and I'll see if it trie to read it.
Before I started working on the board, I took some photos, here are a few of them
Update!
just finished the recap, now the chime is loud and clear.
It seems like the machine is not booting from its hard drive
looking at the floppy port, +5 is 5.00V, +12 is 12.23V but -12V is 0.03V.
EDIT:
I hooked up an external SuperDrive with a copy of the NAD in it, apart from the "blip" that makes after you turn on the system, it does nothing.
I just so happen to have it's original user manual, that also includes pinouts of the various connectors.
It seems like the -12V is not present on this model, so all of the voltages are OK.
I have no idea why it chimes but doesn't boot
But even if the filters (which I have some of them in stock) and/or the SCSI IC are bad, the system should still show something on the display, right?
nope. just a grey screen, with a mouse pointer, if the filter is bad.  or if no screen at all .. then that means UE8 is fried.
the display remains totally black
I can borrow a hot air station from a friend, what is the best way and temperature to remove the chip?
I set my hot air station at 575F
flux and tweezers? - not sure if that was your question.
took a quick look at the schematics: it looks like it needs at least +12V and +5V, -5V and -12V are used only on a few (serial?) chips and on the expansion slot
Update, I replaced UE8 (and lifted a pad in the process of doing it) but the problem is still there.
I repaired the lifted pad and all of the connections seem to mach the ones on the schematic.
Wow looks like you have a couple of problem se/30's.
where are you getting your UE8 from?   LC166 or HC166?
these things go bad a lot.  so sometimes, you can take one from a "parts" board,  and its actually already bad.
The video roms are not the problem, I swapped them and both SE's still show the same problems.
Swapping the roms was one of the things I've tried, I found out that sometimes, the roms in a ceramic package loose their content. (I've spent ages troubleshooting an IBM XT Clone only to find this out...)
UE8 is a new part, it is a SN74LS166AD from TI, I bought it here
I found out that the interrupt key produces a sad mac chime only if you press it after the startup chime, if you wait more that 6-10 seconds it does nothing
on the other hand, the reset button always works
I tried the same thing with the other board (the one with half video) and no matter when you press it (with no drives hooked up), it always makes a sad mac chime (that ends with 13, if I remember correctly)
