Some time ago I added a second battery pack in parallel, that just fits if you split two cells and see the correct position to fit all inside. Now it holds more charge, but frankly speaking, I don't use it much when unplugged...Fair enough, I ended up wiring it up and it seems to work fine, I am just waiting on a SCSI2SD now so I can run battery amnesia
