Hi Everyone!
Ok, so... I got this unit (M5126) a few weeks ago in a very clean but leaked-cap state. I recapped the entire logic board and it booted straight away and works in every way. Except...
After a few days of light use, it began to exhibit a strange PMU(?) issue. It can't go to sleep or stay off when I shut down. It will sleep and wake immediately, but has never frozen coming back from sleep. The only way to make it turn off is to remove the battery and power cord. I decided to play with it some more while writing this post and I can actually turn it off, but I have to be holding a key down... ?
These two short videos better illustrate what's happening and my discovery:
Original issues video: https://www.youtube.com/watch?v=hF6azqrtMx8
Insomnia battle, with keypress trick: https://www.youtube.com/watch?v=z1AaZCw5wso
Does anyone know what might be going on here?
Some things I have done/considered:
- I have not re-capped the LCD board.
- I tried disconnecting the HDD and booted from floppy System 6.0.8. HDD is not the issue.
- I tried disconnecting the floppy and booting OS 7.5 from the HDD. Not the issue.
- I removed the 4MB RAM expansion. Not the issue.
- It has a new lead acid 6V alarm battery in it.
- Should I isopropyl-wash the logic board? I already scrubbed it with warm soapy water and a toothbrush.
Thanks in advance everyone!!
