Macintosh Portable power regulation
You can tweak the PowerBook bricks to limit them at 1.5A, but it seems that rather than current limiting, they just go into protection.
As for the capacitors, they are very simple to fix, I have a video showing how to do it on my YT channel
Techknight is going to yell at you guys for using the gray power bricks!!! I think even with the adjustment inside.. If you value your portable and want less head aches you really should stick to the original white (only) portable a/c adapter.. why chance it! I'm sure you can find one on ebay.. The gray ones have been known to slowly damage them... They are not made for the portable.. they will work but your portable will eventually fail. It's a slow death sometimes....
If you think you know better then by all means go for it..
Never followed any guide, I just made it up of pieces I found in the lab.
Not-so-much-clean now, I just used it for the damn hard drive.
Oh, the white brick works, I'll order the replacement caps anyway.
Two follow up questions.
What is the situation when your floppy drive won't boot and runs slow? I've seen two boards doing that now. Scsi boots fine. Machine is happy Mac otherwise. Internal and external floppy ports suffer the same. Even a floppyemu won't work. Is there an ic to blame?
What does the 16-18 pin 1k resistor trick do, when should I use it?
About the floppy I would start a new thread, as this isn't related to power regulation. I haven't investigated on it, but if you follow the first scheme I posted you should be able to check if there is power first.
16-18 as you can read from techknight's posts is a hack that kickstarts the IC chip into oscillating. As this is a power-saving IC, it compares the values periodically, and not in a continuous mode. Sometimes it gets stuck it seems, and this trick gets it back to checking the input values. Check out the datasheet if you need more info.
Another thing, just to update the topic. The lead-acid cells have arrived and I reassembled the battery pack. It just works perfectly, so absolutely no IC/FET/Transistor was harmed during my awful experiments.
So... it is done now. Everything in full working order, just like new.
I also see that using the bench power supply the computer actually asks for more than 1.5A, so a limiting power brick is mandatory in every case. Like somebody wiser said.. do not use the gray brick. Ever.
Forgot to mention, if you boot to scsi it works but I get the Mac will shut down in 10 seconds message with a full battery and plugged in. So maybe still related to power regulation? Do you solder the resistor or just touch temporarily?
Can you post some details on your workbench setup? How are you powering the mac? What voltage exactly? Using the original wires?
The portable is a bitch with power control and regulation, most problems can be hunted down to incorrect usage I think.
As far as the floppy drive, the SWIM IC is a known failure point in the Portable.
You can find an old SE/30 board or a IIsi board or something that got battery acid exploded, you can pull and swap the SWIM ICs. That should fix it.
Theoretically if one inserted a ram card while the 9v backup battery was active, (big pack removed but battery lid open) would that blow out this swim ic?
it shouldnt.
But I do know that on those machines, if 1 of the 2 red wires loses voltage, it can fry the SWIM, I have witnessed it first hand.
what it does it cause the 5.2V to lose regulation, and will show AC adapter voltage at 7.5 to 7.8VDC, and the SWIM gets hit first.
And to be honest, after following a couple threads, the wiring harnesses are starting to become problematic, Whether its the microswitch or whatnot.
The microswitch if I recall is double-throw. Meaning there are 3 wires that go to it.
If the microswitch gets bad to the point to where the normally closed position is open as well as normally open, it CAN cause the 1-wire only voltage situation which frys the SWIM and causes a shitload of other regulation problems.
So why not tie the two red wires together either in the bundle or on the motherboard? I thought one Input was for the 9v battery only and the other for the large battery? Does using only the large battery with no 9v fry things?
No, the wires are soldered together at the microswitch, any failure of the switch shouldn't impact this, the cables remain shorted.
They both give 6.5V from the lead acid battery OR the 9V battery when flipping the switch. The 9V voltage is dropped by two diodes on the wire.
Then there have been changes over the years, because mine are not wired like that. Only 1 of the wires switches over to 9V from 6V while the other one is hot 6V all the time unless you remove the battery.
Weird, I thought I had the first version. As you can see here, the two wires on the right are soldered together and they go directly to the board. I presume that if you had them separated there could be issues when the main battery was connected without a backup battery (the frying you were talking about), so they had them joined while keeping a hot wire and a smaller one. Just a thought.
This is the rebuilt cable, as before both wires are soldered at the switch.
What diodes did you add to drop the voltage of the 9v? My wire had the diode a while back but the diode burned out and I didn't replace it. I thought it was just a protection diode.
