So I recently acquired a Mac Portable. As soon as it arrived I took it apart, re-capped the motherboard and hooked it up to a replacement battery. Everything was going well, actually no issue at all last night. I was able to mount some Appletalk volumes and play some games, it seemed pretty stable.
This morning I decided to break open the original apple battery and toss my new cell in there. While testing this configuration, I accidentally hooked up the battery with reversed polarity... I know, this was dumb.
Now I'm having issues again. Here are the symptoms:
1. Will not power on at all without wall charger plugged in.
2. Randomly crashes when doing anything.
3. It will go to sleep, but when it wakes up it either crashes with a crash chime or it just reboots.
4. System 6 "battery" meter shows battery slightly above middle charge all the time now (I doubt its accuracy!)
5. When I try to change the date, the system crashes / reboots.
Any ideas? Could it be just a fuse? Is there an easy way to troubleshoot this without a meter?
Thanks in advance! I hope I can get this back to life again...
