Macintosh Portable M5120 Coil Choke Inductor Pulse replacement
Hy Everybody
someone can help me, i'm not in the position to finding in Italy  the same inductor  PULSE PE-53082  8946 IP that  has been damaged, I can not find the datasheet and I ask to you if you know a replacement part with the same characteristics
 thank you !!
Ciao!
Why do you think that the inductor is bad? is it open? usually it is very hard to measure inductance with a multimeter. It might lead you to think that the component is shorted.
From what I remember, the inductor is part of a DC-DC "Boost"converter circuit, the main chip is a LT1070, looking at its datasheet, it looks like it uses a 150uH axial inductor.
At this point, I did a quick search on RS (a large component supplier in Italy), and I found this: PE-52645NL.
I am not sure that the PE-53082 is a 150uH inductor, in power supply designs, they usually choose a slightly higher inductance value than the one recommended by the datasheet.
Once I get some free time, I will look at Portable Board and I will try to find a similar replacement part.
EDIT: maybe this one or this one are suitable replacements, I found this document that lists all of the models from Pulse
Ciao!
Hy Buddies!
Very hard to do with Meter, mine is not the best , testing i report these values as in pics attached
I've broken inductor legs desoldering it ( don't ask me why i've done it! I'm a real As..hole)
Grazie Ferrix i'll get in touch with you in italian ( my english is not so good) !
Thanks Uni for your availability any suggestion about ?
Ciao!
Hi Ferrix have you recapped macintosh portable original ac adapter?
I have followed your videos on you tube and repaired 3 powerbooks 100 adapter ( of 5 not working)
My Macintosh portable ac adapter is not working stable , now i use an aftermarket 1,5 amp but i'd like to repair the original one
maybe the capacitors references are the same .
Ah, i see.. i have an extra i can send you, maybe i can throw it in a parcel back to you?
I have never opened a Macintosh Portable Power Supply (because I don't own one), but I think it is repairable.
You can also tweak a PowerBook 100 PSU to work with a portable, there is a current adjustment trimmer inside.
I'll send you a PM (in Italian) soon
You need continuity check.
Plus that meter is a piece of crap anyway. You need a good one.
I usually recommend Fluke Multimeters, but they are quite expensive, about 100€ for an entry level auto-range model.
If you are on a budget, you can get a UNI-T or Mastech for less than half the the price of the Fluke. just make sure they are auto-ranging meters.
some meters are also able to measure inductors and capacitors, but usually this feature doesn't work that well.
Thanks, good info!
I'm also searching for a multimeter with very thin tips to measure the tiny connectors of PRAM batteries.
Also another thing that will help here is a B&K Precision or the like LCR meter. that will measure the inductance and the Q rating of the coil.
If I am not mistaken, I believe those measured out to be about 150uH.
150uH is the inductance value recommended in the LT1070 datasheet for a 5V to 12V DC-DC Boost Converter
They also recommend this inductor, but it is way bigger than the one mounted on the portable.
But in the inductor's datasheet, they also specify a "C" size that matches with the size of the inductor in the portable, but they only go up to 100uH
