Macintosh plus speed changing clicking no boot sound after recap
So I have a macintosh plus 1mb 120vac from 1987 and I have had some problems. so I picked this mac up at savers for $2 back in December and it looked like someone had it in a garage and also had put some bottle with some fluid on it that had leaked into it but had dried. When I turned it on it constantly made the start up sound and would some times respond with the floppy drives, no picture on the screen. The reasons I did not clean it first was to test the before and after affects so that I didn't damage anything in the process, and the other reason was I'm 16 and my dad wanted to only give it to me for Christmas. So a week or 2 later I opened it to see some corrosion but every thing else looked fine. after cleaning the board it would click slowly. So I don't know if it was a good thing or not but I started replacing the caps. I replaced all the caps I could and checked the ones I could not replace with a capacitor reader. After checking every other diode and transistor I switched it on and it started clicking really fast. I suspect that its a flyback after bringing it into my electronics shop, because I go to a vocational school. I don't have $100 right now to buy a replacement, I would buy a analog board online and steal the flyback, but still its a little over pricey. I mean $40 bucks is a lot, is there any other alternative part or anyone that has another idea for the problem. I would love to have this thing working because I have always wanted one since reference of them through shows and the popularity of them. This would not be the first one I have looked at, I'm not a noob I have worked on one in the past that also had a dead flyback because it was left in a cemetery and the screen was smashed in. It has a mother board that's in better condition but its my friends and the mother board is not the problem. I'm at a dead end what do you guys think I should do. https://www.youtube.com/watch?v=2aERGBzecyE here is a video of the sound
Yeah, probably the flyback if you have ruled out caps. Only other quick thing you could try is resoldering every single solder joint on the analog board. Someone else may have another solution.
Update so I checked the voltage out of the external floppy connector and its giving me .88 volts so that means the board is at least getting power. and the solider joints I looked over all look ok, no cracks or anything.Insert other media
Ok so I switched the old (drops keyboard on macintosh server g4) fly back with a working one from my friend. It cost me a Ibook g4 but the drive was dead and the case was not fitting correctly. So back to the story, I just switched it out 10 mins ago and the Macintosh plus now is clicking slowly i think it would either be a mother board or cap problem what do you think? this flyback worked before so
