Ok i have cleaned the inside and put it together!
And the screen is now not fitting an image, it needs adjusting! and i am not smart when it comes to these things!
Also when i got it the screen shows these lines going vertical down the screen all over the screen! When i hold down the interrupt button i see the lines slowly go down the CRT in sections. Also these dots apeare in a new spot each time i turn it on, i think these dots are where the crt is currently drawing the image when i turn it on. The screen also has not a gray theme but a black one any ideas what i can do to fix most of these problems?
Also if you could i would want to know where to get a boot disk and a mouse?
