Macintosh plus replacment capacitors
Muz_
Hi there just a quick question. I have recently got a macintosh plus. I live in the UK and after the computer has been turned on for a bit my rcd trips so my guess is that there is a rifa gone bad. So I looked at a farnell UK and found some capacitors so I was wondering if you could tell me the capacitors I picked are suitable.
1890199
3519058
Don't use those, the datasheet says "Not suitable for "across the line" applications". You need to match the safety ratings on the caps - so replace class X with class X and class Y with class Y.
I may have some spares suitable I can post you but I can't remember what the specs are. Can you send me a photo of the writing on the caps that are already on the board?
