So awhile ago I picked up a dead Macintosh Plus that ended up being alive after a cleaning and actually plugging in the CRT and other cables. After a full cleaning and such I got to the point where I wanted to run an OS on it.
I am running into the problem of knowing if the drive is good or not now.
In the video I put in a disk with a blessed system folder and finder from my SE as its the only bootable mac I have at the moment, and it shows a happy mac face before trying to eject it (I let it cycle a few times with its broken eject motor verring, as it made a weird noise at first off camera on my first try with that disk)
After that I load a junk ibm formatted 720k disk and the mac does not even try to read it and right away shows a X disk error and trys to eject it
After that I place in a disk from a make a boot disk on an external drive or HD set and it does the same happy mac face and then ejects.
After recording this I make the pink 720k disk into a Macintosh format 800k disk and it did not show the happy mac as the grey formatted one with the blessed files on it
Im not sure at this point if the drive is busted as it can detect disks that SHOULD boot and ignore non bootable ones, just it fails to boot still. The grey disk is a copy of the OS on the SE so it might be too high for it to use? im not sure how these older compact macs work as I was brought into macs with the Imac's. Would love some insight into this puzzle
