I have a Macintosh Plus and a System 6.0.8 Boot Disk (800k floppy). This is the same boot disk I've tried unsuccessfully using on the Macintosh SE.
So, after I finished trying it in the SE again, I put the disk in the Macintosh Plus. It started up fine. Only a mouse was attached, no keyboard.
Then, I carried the Macintosh Plus to another room. Then I decided I would test the keyboard I had fixed (hopefully) earlier. Plugged in the keyboard and mouse and started it up. Got a bomb during startup that an error had occurred and I needed to restart. That repeated a couple times. Thinking maybe the keyboard was causing an issue, I unplugged it. Made no difference.
Finally, it booted but right after displaying the menu and the disk icon (but before displaying the trash icon), it bombed with a system error, saying "coprocessor not installed." Tried rebooting a couple times, but it made no difference. With or without the keyboard, no difference.
It's the same disk that worked earlier in the day. Not sure what the problem could be. Is it a disk problem? Or a problem with the Macintosh Plus?
The disk was formatted on a Quadra 800 running system 7. Mac OS Standard file system, not Mac OS Extended.
