I have something weird going on with a Mac Plus Analog board that I recapped.
I regrettably didn't power it on before I recapped the board but last time, a few weeks ago, it was still working though.
After replacing the capacitors, it didn't want to power on anymore.
I triple checked the polarity and the value of all the capacitors, ESR tested them to make sure, but everything was fine.
There were no lifted traces during soldering: I already re-verified all traces from the capacitor's pins to the next component: all OK.
It's not a faulty switch ( I bridged it for testing ) and the fuse is also good.
However, when playing with the power switch a few times, I found that the board suddenly powers on.
It's very random, sometimes after 3 or 4 attemps, otherwise much more.
When it's on, I tested the voltage on all reference points from a schematic in Larry Pina's book: everything is spot on.
I left it on for 3 hours: nothing smoked/overheated, stable as a rock but the power on problem remains.
Has anyone seen a problem like this ? It's not a dead set but there's definately a problem somewhere.
Unless someone has an idea, I will have to look for the schematics and verify the whole power supply section. :'(
