Shouldn’t have any issues clean it and then post some pictures.I'm quite confident at recapping / resoldering..., my concern is that this time I see the board in a very bad state,,,
EGRETcontrols power functions on these machinesHi, I was not expecting winegear to be good for cleaning boards.
I have done a first cleaning and I tried to powerup the 5V. I can barely hear the chime !
Tomorrow I'll start recap, better cleaning and some reflow.
I'm wondering one thing... why egret chip on an hardware poweron machine ?
Those are left as is, no need to worry about them.Update, all caps removed and some new one has been already installed. I'm waiting for the 10uF / 16V, hope to get these by Tuesday.
I think the Egret works fine as I could barely hear the chime at startup and, triggering interrupt by Command-Power on keyboard, I can hear also listen at the death chime.
Looking at the board,... close to the battery holder there is a "jumper block" A21/A20/CPE, do you know what is the purpose ?
There is also a small connector called J2 near the display out port, ideas?
Thank you
Sweet she livesHi everyone, sorry for the late, I finally recapped the entire logic board, it took a while to obtain all the new tantalium caps. Now the chime sound is mych better, crystal clear, attached floppy Emu and it s reading it. I cannot connect a display right now but I should be able in the coming days.
Hopefully everything works.
Btw, the power supply is failed, I'm going to recap that one too, so for now I tested with an alternate power source.
Thank you very much!
I would remove it, remove old solder from the pads, clean with alcohol, and then solder it back on.Hi,
I just recapped the power supply too and now machine boots untethered, I have also installed additional VRAM in order to support VGA resolution. Everything works, but now I have very low or no sound, should I try to reflow the sound chip ?
Sweet happy she’s running again!Hi everyone, after replacing the amplifier chip no luck, that I removed the Apple sound chip, cleaned the pads and the chip, re-soldered it... and YES, everything is ok now! crystal clear sound !
Thank you all
