I purchased 8x 2MB RAM chips for my Mac IIx from WeLoveMacs and no matter what combination I try, I can't get any of the chips to register. Essentially, any combination outside of the original 8x 1MB configuration leads to the error chimes. I've spent loads of time on various forums and websites suggesting specific combinations, but none of those have worked thus far. In the configurations in which I use only 4 2MB chips, I've made sure that I tried different 2MB chips multiple times in order to help eliminate some of the chance that one or more chips might be bad. Any suggestions? Here's what I've tried:
8x 1MB (Bay A and B ) - WORKS
8x 2MB (A and B ) - DOESN'T WORK
4x 1MB (A) and 4x 2MB (B )- DOESN'T WORK
4x 2MB (A) and 4x 1MB (B )- DOESN'T WORK
4x 2MB (Bay A only) - DOESN'T WORK
4x 2MB (Bay B only) - DOESN'T WORK
It's worth noting that the computer doesn't get past the error chimes with any of those configurations (except of course the 8x 1MB configuration). I have Mode 32 installed. The chips don't need to be PAL chips, as far as I know, because they're only 2MB each. Any help would be appreciated.
Regards,
LazarusNine
P.S. Can the RAM in the IIx be used in an SE/30? If so, it's worth noting that I face the exact same issues with the SE/30, but the RAM was purchased specifically for the IIx (as it was advertised).
Regards,
LazarusNine
