Macintosh IIci gives chimes of death; memory trouble?
You can only edit for a certain window of time.
edit: That RAM will work, but for $9.95 you can get new 16MB SIMMs from OWC.
The computer now works and reliably (I think; I only tried it a few times) boots! Thank you, RalfK. Thank you, Elfen. Thank you, Unity. Thank you, Uniserver (for the recap).
Now I just have to figure out how to fix the floppy drive...
YAY!!!!   Well the floppy *can* be the easy part. Lubrication is first step. Cleaning the heads is second. Just be glad its not a 400k drive, those can be a PAIN.
Congrats Tanuki65! The floppy should not be hard as Unity stated. And as long as you have the plastics to have it in its place, you should be fine!
Did you Lubed it? You should clean it up and lube it.
Unfortunately I cant find the instruction that was on the wiki as the wiki is still down. But you could probably google the information.
