mac SE won't boot, mac classic 2 with horizontial lines in the left and right corner.
Still terribly blurry at the CRT neck, but I'm almost certain the thing is done. Here is a photo of what should be there on these two CRTs. Notice in between the pins, there is a tiny piece of glass sticking up. That has broken off yours, leading to a loss of vacuum in the tube. It is useless now.
yeah mine doesn't have that just bare pins that look bent. must of happend when i took of the case. so does anyone want a SE thats unknown?
i think i found the culprit. the pram battery appears to have leaked i see a little bit of oxide on the bottom  of the board. but for the life of me i think figure out how to remove it. the manuel just says remove it not how
ok the battery and the compartment are clean. now either the sweep board or the crt itself. im leaning towards the board. the manual says it comes right out not so much.
