Mac Classic floppy giving error message that all disks are unreadable or damaged, both before and after a refurb, cleaning and lube
Someone suggested that replacing the PRAM battery could be a solution, but I'm not sure. The drive is very clean and functions perfectly mechanically, yet despite this, it refusing to read any disks (even tho they are read perfectly on my LC II). Any idea why a functioning floppy drive would have issues reading? Thanks
Howdy!
Have you tested the floppy drive from the Classic in your LCIII to confirm that the drive itself is not the problem?
The head assembly
could be out of alignment. Pina’s guides have a comprehensive section about how to diagnose and fix this.
There are components on the mother board that can fail and cause the symptoms you are seeing, but it could also be the floppy drive.
You'll have to find some way to test the floppy drive with another computer to isolate the problem.
Or test another known good drive in your computer.
Look online for a pdf copy of Dead Mac Scrolls by Larry Pina and Mac Classic & SE Repair and Upgrade Secrets also by Pina.
They contain information about troubleshooting floppy drive issues.
