Mac Classic Error Code Help
pj931
Hi,
I posted a bit ago with some CRT issues and 5v/12v issues. Another Mac has been (mostly) liberated by changed TDA 4605, DP6, CP23 and the zener diodes around TDA4605.
Now I am getting the error code pictured. I understand it is a RAM bank failure in Bank B but I’m not sure what the 0400 in the bottom row means. I also don’t know which RAM chip is represented by Bank B. This error appears with or without the memory expansion installed.
I have recapped both the analog and logic boards and any and all electrolytic leak was neutralized with vinegar then rinsed with IPA.
There are 1MB RAM on the logic board. One of these chips could be defect.
The 400 means that bit 8 to 15 showed the error.
