I know this has come up before, but I wanted to just go over it again prior to my impending move.
Basically, I am moving into a smaller transitional space which will not accommodate my "Mac room". This could last up to a year or longer depending on where I move next. My solution was to rent a Public Storage space in a climate controlled building, for the Macs as well as a bunch of other stuff I won't have room to keep on site.
That said, I have pulled the PRAM batteries from all the compacts. Aside from the caps, for which there's little else I can do to prevent leakage, is there anything else I should do for the compacts? I did pull all the logic boards and are storing them separately standing vertically in a file box, in the event the analogue board's caps should begin to leak as I am storing the compacts on their sides to better fit in the shelving units I have.
In addition, I have a few puzzlers. I also have a number of PowerBooks, for which I have removed all of the rechargeable batteries and packed in plastic containers. Though they are long dead, I can't really throw them away since they are integral to the laptops design. I suppose I could crack them open and discard the cells, but is that overkill? It also occurs to me that I might need to also open them up and remove the PRAM batteries, or are they relatively free from leakage? I've never seen a corroded PRAM battery in a laptop, though assume it could happen.
Lastly, I have a Mac Portable with a lead acid battery. Should I remove this and store separately, or at a minimum wrap it in plastic? Or is wrapping these batteries in plastic only going to encourage corrosion?
Is there any special consideration I should give to external drives, keyboards, etc. That I may perhaps be overlooking?
