Hi all,
I need a little help with the adjustment procedure for the optics system with NeoWidex on the Lisa Widget 10MB hard disk. I have two units here that are in need of an adjustment that I just can't seem to get right. One was a working drive that I sacrificed for a sanity check. I tweaked just one pot back and forth to the original position, and now the drive does not work.
Moving the actuator back and forth by hand results in a very unsteady image on the scope, so I suspect that's why my alignments are invalid. I want to know how to initiate the procedures on this page (http://john.ccac.rwth-aachen.de:8000/patrick/UsbWidExamples.htm#session4) using NeoWidex. as I do not have a UsbWidEx. Specifically, the alternate seek command (a) and the forward seek command (f). I have been using the keyboard to manually seek, watch the scope, adjust, then go back, which is tedious. Are these commands implemented in NeoWidex?
