LCII Squealing noise from speaker
I pulled out a spare LCII board I had to see if it worked and it chimes and boots fine but it squeals from the speaker. When I push and pull on the speaker connector the pitch goes up and down. Attached is a video. Any ideas?
Right, a recap should come first.
On the LCIII, the noise can persist after a recap. Changing one of the cap values breaks the oscillation. This may also apply to the LCII, though likely with a different designator:
I'll have to recap it first I guess. I hesitated because I just recapped my other one and it still gets no chime and a black screen. LCs are a pain to recap, lot's of caps and some are in really tight spots, like C10.
I can also confirm that I repaired multiple LCIIs that all did this. Every time the problem were capacitors. They are just bad.
And the first one that I came across with this problem was back in 2011, so at that time the machine was "merely" 19 years old, this is the same age now a G5 iMac or a late Pentium 4 machine is.
Also they need PSU recapped, especially if they are TDK brand.
