LC475 hard disk problem
toples50
I've purchased recently a LC475 but I have problem with the hard disc.Doe not recognized any hard disk drive I've tried.I've used the HD SC setup v7.3.2 from 7.5 installation disks but without luck.With 3 different hard disk I've got the same message:Unable to locate a suitable drive connected to the scsi port
First of all: Has it been recapped? If not, then that should be your #1 priority.
Second thing: Try Lido instead of HD SC Setup... If the hard drives don't have the Apple firmware (no Apple logo on the sticker), then HD SC setup won't be able to see them unless it's been patched. Since you're using the original Apple disks, I very much doubt it.
Did you make sure the scsi pinout on the drive was set to the correct ID? I believe 3 was the internal scsi for the hard drive (though it has been a long time).
