Afternoon folks.
My dad dropped over an original (020) LC last week and I've been bringing it up. Its in reasonable condition, corrosion wasn't too bad. I've recaped it, I'm using a known good PSU, and has been cleaned in an ultrasonic.
So far, the PSU was dead, then it wouldn't chime until I recapped it. Now its slightly hesitant to show the question mark, and if I boot it from a floppy disk, it doesn't see anything on the SCSI bus. Internal or external. The Egret was a bit grotty, but not so bad that I'd assume it was damaged.
Interestingly where SCSI Probe tells you whether the bus is terminated or not, that is working. So SCSI Probe tells me that the bus is not terminated if I have absolutely nothing connected to SCSI.
Any common issues likely to cause SCSI detection issues, before I get stuck in?
Please remember that I'm limited to a floppy drive and I'm not really a... floppy drive user so I'm going to struggle to run much software on this. To hand I have System 6.0.7, HD SC Setup, Drive Setup (a 7.5.3 disk that boots straight into drive setup), SCSI Probe and not much else.
