Hi All,
I recently picked up two video cards for the LC PDS slot. I'm not sure where to find the drivers as Google isn't really turning up any good results.
The first card is a Formac Pronitron LC/FP display video card. It appears to have the standard 15 pin Macintosh video connector on it. Does anyone know where I can find the drivers for this card? Also, a user manual would be awesome. I'm hoping to use it with a VGA adapter to drive an external display at 640*480.
The second card is also a Formac labled model. However, I'm less sure of which one it is exactly. A sticker on the ROM says PG/LC Rev. 1.0. Additionally, it isn't using a standard 15 pin Mac video connector, but rather a connector that looks similar to VGA, but only has two rows of pins, with 5 pins on the top row and 4 pins on the bottom row. Does anyone know any more details about this card or at least what type of connector it is?
If photos are required of either card I can provide them.
Thanks,
Justin
Thanks,
Justin
