I recently picked up an LC III, when I first powered it on everything worked great, I had video and a startup chime. On about the fifth time I powered it on the startup chime was garbled, and after that it never chimed again. I have also tried headphones, no chime. When I have headphones plugged in and switch the machine on, I can hear a quiet pop like something is initializing. I recapped the logic board and that did not fix the problem. Everything else still works, video is fine, and the machine functions normally other than no audio. I also followed the instructions in the post linked below to check continuity, everything is good. Does anyone have suggestions for further troubleshooting?
Edit: I do not have a PRAM battery, I still tried the PRAM reset as MrFahrenheit suggested in another thread, though I only did it 10 times and not the 11 that was suggested.
68kmla.org
LC III - No video, no sound, and weird schematic
Hi everyone! I recently acquired an LC III which I’ve recapped (both the logic board and the power supply). After recapping, the machine will power on, but will not output any video, and only outputs sound via the speaker jack in the back. I get a boot chime which is immediately followed by a...
68kmla.org
