LC-II Shine! I mcdermd'd my LC2, POLISHED! Nice :)
Given the huge number of LC-II's that were in schools, a lot of people, myself included likely have some nostalgic memories. They're compact and usable machines that can still run a fair bit of popular software from the era, 8MB was still considered a LOT of RAM at the time. While it bugs me that they were artificially crippled, I can understand Apple not wanting businesses to stuff a load of RAM into their cheap low-profit consumer machines rather than buying the high end more expandable and much more costly/profitable Macs to run Photoshop and CAD.
Actually will be picking up another LCII next weekend (and am thinking of getting another one later on). I like the simplicity of the design and for what I use older Macs for (educational titles), they're not only perfect in terms of how much power they have, they're also the quintessential machine for education programs due to their ubiquity in schools.
Also underrated is the 12" RGB. It may have a quirky 512 x 384 resolution, but it's not too far off from the compacts and has a nice fullscreen touch for some programs which otherwise would run inside a window on a 640 x 480 monitor. The way it matches the LC itself (also the IIsi) is also great.
Nice Bronner's reference!!! Actually went there 20 years ago, went to Frankenmuth en route to Duluth and stopped there. Thinking of heading up that way in October for a nice weekend at the Bavarian Inn with some fine food to go along with it. It's the closest thing to actually going to Mittenwald :-)
Others must agree with me, because I'v recapped a crap load for people so far.
I would bet money that this is mostly because of nostalgia, and the fact that they are THE most common 68k out there at this point and a good starter machine for someone just getting into the hobby.
YES! I have two of these monitors saved just because I like them so much. I always thought the color quality on them was excellent too, much better than the 13" and 14" monitors that were also commonly found with the pizza box Macs.
I cut and pasted this from a blog,
This breaks down Plegde and why it works, and what is in it.
http://www.hdtalking.com/touring_models/13248-chemical_analysis_of_pledge_furniture_polish.html
I ran across this on another site and thought it might make for interesting reading for all those folks who make fun of old timers who have used Pledge on our cars and bikes for years. The man who wrote it claims to be a chemical engineer. For whatever it is worth, I don't use the Pledge brand anymore but substitute the cheap stuff found at the Dollar store, which costs $1.50 for a tall aerosol can. It works just as good and costs about a third of what the name brand Pledge costs.
Lets start out with the actual ingredients found in a spray can of Pledge.
Please note that the base formula will be different being dispensed from a spray can or pressurized aerosol vessel due to the fact that a "propellant" is needed to transfer the product from the container to a surface, in this case lets say a fender or a windshield. A trigger plastic spray container would not require this propellant additive.
For the purpose of this discussion, I will list the information relative to Pledge in the aerosol spray can as it appears to be the most common used by others on this forum.
The base ingredients are:
1. Naphtha, petroleum, light alkylate 5%-10% or (isoparaffinic hydrocarbon solvent)
2. Polydimethylsiloxanes (Silicon oil) 5%-10%
3. Water 70%-85%
4. Butane1% -5%
5. Isobutane1% - 5%
6. Propane1% - 5%
Now we can breakdown what these are and what they do.
The first ingredient is:
1-Naphta,petroleum,light alkylate.
This is a hydrocarbon solvent-based dispersant formulation which combines oil penetrability. In other words remember the label says "smear and smudge proof"? These are the ingredients that will break down and remove the smears, finger or dermal tissue oils. Criminals take note.. use this to eliminate finger prints. Just dont be a dumb (EDITED) and leave the can behind!!
Now, what is a hydrocarbon?
A general term for organic compounds which contain only carbon and hydrogen. They are divided into saturated and unsaturated hydrocarbons, aliphatic (alkane or fatty) and aromatic (benzene) hydrocarbons. Crude
oil is essentially a complex mixture of hydrocarbons.
To break it down even further, I will now define an organic compound.
An organic compound is any member of a large class of chemical
compounds whose molecules contain carbon.
What is carbon you asked? I knew ya would!!
Carbon is a chemical element with symbol C and atomic number 6. As a member of group 14 on the periodic table, it is nonmetallic and tetravalent (a state of an atom with four electrons making four electrons available to form covalent chemical bonds.)
A chemical element is a type of atom that is distinguished by its atomic number; that is, by the number of protons in its nucleus. The term is also used to refer to a pure chemical substance composed.
What does this all mean?? It is a pure chemical substance.
Why is it in there? Remember the finger print? It is a solvent that removes oily residues. This is the cleaning agent in the product.
Look at the can.."It dusts and cleans". this is what makes it clean/remove dirt,grease,oil,grime.
That was the more lenghty one. The remainder are relatively simple. If you are still reading at this point, thanks for bearing with me.Go grab another beer! I will summarize at the end and compare to other products on the market in terms of ingredients, costs and results.
The second noted ingredient is:
2-Polydimethylsiloxanes or Silicon oil 5%-10%.
This is silicone based oil. The molecular structure of this is such that friction is significantly reduced. This nifty additional ingredient is also the reason why the ..refer to label again.. NO WAX BUILD-UP!! Silicone will blend with it'self and not mix or layer with other chemicals.
It does however have the ability to piss bike painters off due to the fact that it needs to be completely removed proir to coating with paint. If not...start all over again. It makes surfaces slick so that nothing sticks. It also provides the shine to the surface.
This chemical is also present in 95% of products us bikers use on our scoots such as Armor All, Meguires Wax and STP Son of a Gun just to mentiion a few so if you are worried about using Pledge in the past on your bike, you may alraedy have and just did not know it.
This silicone oil is also an ingredient in Right Guard deodorant, baby powder,Desitin, Gillette Dry and several moisturizers and creams. This is why Pledge does not contain wax, they use this instead.
Makes me want to try it with the goa....wife!
To the guy that posted about the fella steping on his fender and sliding off...about to 5 drops of this in a drink will cause lets just say possible incontenence" which will then require the need for additional Desitin with the same ingredient to help that diaper rash from the copiuos ammounts of passing solids!!! Great stuff ain it?
The third ingredient:
3-Water. This acts as a dilutor. Kind of like "filler" in cheap dog food but in liquid form.
Cant use the product undiluted.
The remaining butane, isobutane and propane are the propellants that assist in expelling or propelling the liquid product from the can. The methane is building under pressure and the propane, butane provides the ignition source. Kinda like putting your tounge on a 9v battery. You know you are gonna do it eventually when no one is looking. Try chewing aluminum foil!! Nah...dont do that either.
Other ingredients such as aromatic compound like orange, lemon or any other organic scent additive can also be incorporated.
Now with this little snippet of knowledge, how does one apply it to everyday living.
If Martha Stewart says that a prison panty liner work just as well as a microfibre cloth stop reading. If not..please bear with me for I am almost done.
Several products out there are costly for several reasons. 1 because of proprietary ingredients/raw materials, 2 advertising costs, supply and demand and product to market costs. What will the market bear? I have always compared ingredient when shopping. Silicone oil is silicone oil, Pepto Bismal, for the guy trying to stand on the fender coated with silicone oil is pink Bismuth...same thing!
Pink bismuth is MUCH cheaper.
I heard of a product called Plexus. A great cleaner and conditioner for Lexan. At $15.95 for a 13oz can versus an 18oz $4.99? can of Pledge? I have not bought or used Pledge and do not know the actual cost I am sure it is not even close to this other product.
In summary:
* Will not damage finish
* Will provide a nice shine
* Will not build up or layer
* Safe on windshield. No alcohol or amonia
* Safe on chrome
* Also has some (although not real good) anti corrosion properties. I use Boeshield T-9 for this application.
One precaution!! Flammable! Do not use around open flames or on hot pipes or other hot components. Do not get on or use on denim ar matted finishes!!
I would also highly recommend that a wet or water wash, or a soft wetted cloth, (I use warm clothes because the heat helps soften bug guts better than cold) be done or used first to remove surface debris and particulate from the soon to be applied to surface, fenders, gas tanks,side panels. This will reduce potential scratching of your paint.
Well, I hoped this helps. Like I said, I have never used "Pledge". But I have applied the same ingredients in Pledge (just under a different name...Maguires Wax) on my bikes not knowing it, and they have all looked great!
No get off the computer and spray your bike with Pledge!, or go riding...
Thank you for this extensive explanation on Pledge, Armor All etc.!
Years ago I found Silicone Oil being a main ingedient of such mixtures. As I learned in materials science, silicone oil can severely harm the durability of many plastics. The tensile strength of silicone treated fabrics like polyamide (Nylon) is easily cut by a half, compared to its natural state. Some plastics, like polypropylene, might even break from internal stresses under influence of silicone oil. Some plastics seem not to be affected that much, but in any case you will have a hard time if ever you would try to glue or paint anything that came near a bottle of silicone oil, ever. Stickers will not stick anymore, also. There are some chemicals called "silicone remover" in the market, sold to prepare carbodies prior to a paint job, but they will help only halfways and most likely damage plastics like ABS. There is nearly no way to get this silicone oil completely removed from a surface, once contaminated. Usually the benefit of such silicone oil treatment will not exceed the trouble you get in case of a need for real repair jobs, that include deep cleaning or glueing of broken parts. As an addition the silicone oil will spread from the tretated surface to anything else nearby, just by the touch of hands. This holds true for a dashboard in a vintage car as well as for your Mac. Take care.
On some kinds of plastics silicone oil does support a nice look without doing harm to the structure. It is known and used for the effect to avoid anything else to adhere to the surface covered with silicone oil. However, some plastics might be damaged severely. In any case silicone oil turns out to be a real mess as soon as one actually wants something to stick again to a part formerly treated with silicone oil.
We know how different Macintosh case plastics age. Often enough Apple used different batches of plastics for different parts of the very same machine. Some become brittle, some become brown, some stay as they are. PVC or Vinyl is not common in Macintosh cases. We find ABS, PC PMMA and other blends with a variety of fillers, colourants and flame retardants. None of the ingredients will interact chemically with the silicone oil, but the silicone oil spreads completely on the whole surface and into each tiny little crack. It changes the surface energy strongly and will stay permanently. Even sanding the surface will not completely remove the silicone oil as long as some of the original part is left.
It is strongly recommended to do some experiments with that stuff before an attempt to contaminate valuable things with silicone oil. If it works for you, it is fine. Final it will be, also.
