Folks, I wonder if someone could shed some light on this.
(TLDR - LCII sound only works with board in case, not with board sitting on the desk)
I have an LCII that basically works but squeals a little. Originally, the sound was pretty bad, but I cleaned the cap fluid stuff and the sound became nice and strong. However, it was still squealing a little, so I decided it's time to recap. I replaced the capacitors around the 78L08 - and now I have no sound whatsoever. Actually, I can hear something really faint, but I can barely recognize it.
Anyway - I was checking the schematics, trying to understand how the audio part works, and I run into something I don't get. The 78L08 gets the input voltage from the 12V line through R114, which is 47Ohm resistor.
However, the audio part uses different ground that's not connected to power supply ground at all !!!
There's no connection between the two ground planes. Measuring the resistance between the two ground planes shows open circuit. Input voltage of the 78L08 is somewhere around 4V, not 12V.
This is obviously a nonsense, so I was wondering WTF. Based on the schematics, the audio ground is also used with filtering caps on the parallel port, so that got me thinking - is this the frame ground, so it's supposed to be connected to the frame of the power supply?
I should mention I was testing just the board alone on my desk, not the whole computer in case. I felt pretty stupid, but I moved the power supply closer to the board, making sure the metal of the power supply touches the frame of the video connector.
Surprise!
Nice and clean sound!
The only problem was testing the board outside of the LCII case!
Is this a known fact? Am I just being stupid?
Could it be that some folks complaining about no sound after recap are actually testing just the board on open bench?
Surprise!
