Thanks to djcommie overhere I obtained a LC PIVOT INTERFACE.
I was hoping it would give my LC II a much needed graphics boost. Sadly I doesn't seem able to do higher resolutions then the standard 640X480.
There are a lot of cool functions but you need a pivot monitor for that. This pivot interface came without FPU, but I installed one. That one I took out of the FPU only PDS card.
The one big advantage right know I that I was able to take the vram out of my LC II and in to my Quadra 700. So that my Q700 can handle better resolutions. Huzzah!
It is a cool expansion size the board itself is as big the LC II motherboard. I wonder if it will work in my LCIII+
If you go to the 68kmla flickr group you can see all sizes of the picture
