Hi all,
I've been googling and searching the forum, but I don't know if I've found a clear answer to this question: can I use a LC power supply in an LC II, and vice versa?
The LC uses model number 699-1053: http://imgur.com/gIQGXRm
The LC II uses model number 614-0003: http://imgur.com/KHi4V28
The output on the LC II is a tad higher, but I've seen people say that it can be done for testing purposes, but maybe not great as a long term solution. The LC power supply that I have is faulty, but ideally I'd like to pop in the LC II's to see if it works otherwise. It seems like I can, but I figured I'd run it by the commentariat first.
Thanks in advance!
Thanks in advance!
