Yes, the Macintosh will be able to drive this printer even directly, as long as you have:I will be getting a new, old printer - An HP laserjet 4L. Can I do anything w/ it's parallel port?
No, it must be an original CSI card. Comm Slot II cards are designed for PCI based systems - the 6360, x400/x500 series systems as well as the TAM. CSI and CSII cards are not interchangeable, they are not electrically or physically compatible.OK, I'm currently looking at a Comm Slot II Ethernet card online - will it work in my LC 575's Comm Slot?
(snip)
B) the PostScript raster image processing software ("RIP") TScript. Preferred choice because of superior printout quality, several useful features to support vector graphics output and also the option to share the printer with other Macs in a LocalTalk network.
c) other RIP software that might be available, like Birmy PowerRip.
Linux has a perfectly fine Postscript processor available, "Ghostscript", and it can be easily set up to autofilter incoming print jobs. (I'm fairly certain Ubuntu sets up CUPS to magicfilter Postscript out of the box, but I'm not 100% positive. You may have to manually add a package or tweak the CUPS config.) If you hook the LaserJet up to a Linux machine that has Ghostscript filtering enabled then you won't need to fiddle with any software on the Mac at all, just use the Laserwriter driver.@Cory5412 That idea sounds really good, as it would allow me to share virtually any printer w/ the Mac. I assume that a combination of Netatalk and Samba would allow the Mac to use the Vista printer, or I could simply hook up my 4L to the Linux machine.
I have an older test computer (actually once my main computer) that I could set up for this, but I'd prefer to use Ubuntu, simply because I have experience with it.
