LC 520 burning question...
macguy
My LC520 has external scsi and running OS 7.6.1.
( At one time i had an external hard drive via scsi but that external drive and it's replacement had a horrible death. RIP dear drives. )
Would I be able to scsi a external CD burner, install Adaptec Toast and burn?
( i have a couple of external scsi CD burners and Adaptec Toast used by my Performa 6360 and Roland VS1680 hard disk recorder )
Should work just fine. Just make sure you use Toast 4 or earlier, as it's the last one that works with a 68k processor.
But, to answer your implied subject-line question: No, you shouldn't burn an LC 520. It would release toxic fumes.
hummmmmm
will check the version of Adaptec Toast i have and may have to go on a hunt for Toast 4.
Installed version 4 but the LC520 ( OS 7.6.1 ) does down when Toast 4 is launched.
Is there a Toast 3 or 2 somewhere ?
