I'm doing a routine check to see that both my LaserWriter Plus and IIg are behaving fine.
The plus I have never really used because when I got it all the trays were missing. After I got the IIg I tried one of its trays but they were too wide. Where can you still find the proper size paper trays? The printer otherwise seems to go ready if you trick it into thinking a tray is installed.
The IIg however is a bit more cranky. When you turn it on you get that jet-engine spin-up, which promptly stops and the indicators flash the toner light and illuminates the paper tray light. I have a tray loaded with paper and installed and to my knowledge the toner cartridge is healthy so I don't see what's wrong. Is this an alternate error code?
