I don't see any identifying marks to tell the manufacturer but the card with the chip labeled "HD6845R" is almost certainly an 80 column video card. It's a different layout from my Videx Videoterm but it has essentially the same components. Likewise I see no useful identifying marks on the other card but since it has a Z-80 CPU on it it's undoubtedly for running CP/M. It looks suspiciously like the Unitron Z80 card here, but I also see poking around that what looks like the same card was sold under other names with different silkscreens. So maybe it's a "Wacky Bob's House Of Computers Z-80-o-tronic" house brand.I am new to the Apple II world -- can someone identify the two cards and third "add on" I found inside the machine? (See pictures attached).
(There's also a directory for 80 column cards on the same site, you can probably match your card there.)
The last dingus, the Sup-R-Mod, is an RF Modulator for hooking up to a TV on channel 33 UHF instead of a composite monitor. Guessing you probably don't need that.
I also have a question -- when I tried to load a couple of games, it said that it could not run them because the diskette required 64k of RAM. I was confused by this because this Apple II plus has the language card in it and therefore HAS 64k of RAM. Also one of the games (Oregon Trail) is one that I see all sorts of Apple II plus-es running on Youtube..
So what happens when you boot a plain old DOS 3.3 MASTER disk from cold? The first thing that should come up on the screen if the system is working is a message telling you it's loading Integer basic into the language card. I'm sort of wondering if maybe the language card has some issue that's preventing it from being detected? (In which case your system is acting like an-Applesoft-only 48k Plus?)
