Hi, I had a couple Jaz external drives (the green ones, 1 GB cartidge capacity) that I plugged in my Iici alternately, to play around and test them. The original PSU was included with one of them, so I could power up both, to discover that one was somehow faulty while accessing the cartridge, while the second one was working perfectly. So I created a backup cartridge, worked a couple of hours on it to move software etc...
the next morning, no power when I turned on the Jaz Drive - nothing with the other one too. Is the PSU dead? I cannot get any voltage from the pins indeed...
is a modern replacement ok with the pinout? I found a +5 / +12 with the same pins but... will they carry the same voltages? OR there are other known causes for this behavior? Any hint appreciated!
