I am doing a bit of modification to the inside of my Color Classic trying to fit a SSD solution. I need a move things around a little and I need a cable that can extend a 50 pin internal SCSI ribbon cable.
If you're good at soldering, you could probably make a little two-socket board... Or you might be able to talk one of the solder-wizards around here (of which I am not one) into making it for you
Or get a couple of crimp IDC connectors and some ribbon cable, and make one up to the desired length. If you don't have a proper crimping tool, a bench vise will do the job. Pliers even, if you're desperate. I did it with my teeth once, but I don't recommend that approach.
In that case, just get the IDC-50 male and lop off a redundant internal SCSI cable.
The ready-made cable is by far the most convenient.If not quite the most economical solution at $8.95, it's not far off. Even a single IDC-50M will be likely be a couple of bucks shipped.
