Info on a PB G3 Bronze Keyboard
LaPorta
68LC040
Hey everyone,
I just purchased a G3 off of eBay:
Just looking to see if these can use the iBook G3 yo-yo adapter or 1400 adapter. Anything else that I need to know about these machines? I have never had a G3 PowerBook before.
There are two different yoyos though. You want the one with the bigger (wider) tip. On ebay these are usually more expensive (about $115) unfortunately. Also. Not to be confused with the iBooks g4 yoyos which have a narrower tip.
Wow!
Looking at my Pismo's original power supply, which I'm still using, it's 24v just under 2A. Suitable power supplies spec wise are easy to find, but I've never looked for the connector itself.
