Hey friends,
I've been learning a lot here, I'm not green to retro hardware but I'm new to Powerbook restoration. I picked up a 180 that seems to be in perfect shape, been sitting in a padded bag for 25 years. The battery is toast of course but didn't leak. It powers up and works a treat with the battery removed using the original power supply. I'd like to make this a daily driver I'd appreciate thoughts/ideas for anything I should do to keep it healthy. My primary goal is to do no harm.
Hinges: I have mostly seen videos about repairing cracked hinges, but this one seems to be (for now) totally intact, and I would love for it to stay that way. I was going to take the bezel off and do some very light reinforcement around the plastic hinge standoffs with some JB weld. Worth it? Any other things I should reinforce or lubricate while I'm in there? Or is it better to wait and see. I do epoxy/resin casting so I have a few options here and am pretty familiar with it.
Battery: These seem like a bit of a pain to rebuild if you don't have a spot welder, which I don't. I was considering building a little step-up USB-to-barrel-jack cable so I could get ~7.5v out of a USB battery bank and just power through the AC adapter port. This has been a successful non-invasive portable power solution for lots of other machines, but any gotchas here on a 180?
The other idea was to 3D print a battery casing and just throw an off-the-shelf 6v NiMH pack in there (with an inline fuse of some sort). It would be only be ~2000mah, but maybe with a ZuluSCSI instead of a spinny drive it would last a couple hours? Price + effort level is right, would be easy to make a couple. Open to thoughts here too!
Floppy: also working fine, and I figure it'll stop working long before the belt is goo, but anything to do here?
Power supply: mine's working fine now, but seems like the consensus is I should recap before it fails. can these fail in a way that could damage the computer, or do they tend to just lose amperage if the caps go?
OK thanks very much!
-Charlie
-Charlie
