Hey guys,
I have an original ImageWriter from 1984 (photo here). It actually still works!
I found the ribbon "ink" for it at Staples (2 packs for $15) and some old paper. The printer works fine in Windows XP using an old C. Itoh 8510 driver, using a COM1 to 25-pin Serial (looks like SCSI) cable. Anyway printing in Windows has given me some issues and I wanted to see if I can get it to work on a Mac.
I have a Mac 512k with the printer cable but, I can't get that machine to boot up right now. I have a PowerBook 540c and and this Apple Serial to 25-pin Serial cable. The PowerBook is running Mac OS 8 I believe.
I have the proper printer extension loaded and select it in Chooser, but when I go to print the machine seems to freeze up. Before it gave me an error saying "SimpleText can not print to this printer, please select a printer using Chooser" - or something like that.
Any ideas how to get this printer to actually print on a Mac?
Thanks!
Update: I just tried to print a text file using the same cable I used with the PowerBook on my Macintosh IIci - I get the same error. "The Printer is not responding. Check the "select" switch. Click OK to continue, Cancel to terminate printing." The Mac IIci is running System 7.5.3. If I click cancel I get "SimpleText is unable tp print this document. Please use the Chooser to select a printer." I'm guessing the cable I'm using is the wrong one, or possibly there is no way to use the printer on a Mac with only the printer/modem style serial ports. :?:
Thanks!
