iMac G3 help
So my iMac G3 DV Graphite that I rescued from a trash heap makes a whirring noise when turned on, then the light goes green, then it shuts off after a second. My other iMac G3 (Bondi Blue Revision A) just makes a humming noise when it gets plugged in and no power light, nothing shows up on the screen, nothing. Does any body know what's wrong with these 2 beauties?
Hi
I also have this buzzing in all my iMac G3s TL when on stan-by.
It is coming from the Power Supply board and it starts as soon as I plug it to the mains.
Something is vibrating and emitting a high pitch sound that is hard to pinpoint even with the board uncovered.
Maybe a thermal scan could help locate the culprit, I dunno.
Unfortunately, while I have just reassemble one Rev. B, I took no pictures of the board's components.
But I have scanned the reverse of the PS board.
Would love to ear from the electronics wizards in da house.
Another fun fact I have come to know about these iMacs.
Sometimes, after some random operation, it stops working and it just there, buzzing.
You press the power button and it just makes a different buzz while you are pressing it.
You lay it to rest unconnected and in the following day everything is OK - like if it never happened... :p
What can I say, I just love these colorful, child-like contraptions :)
