Haven't touched my Bondi G4 in 9-10 months and come to find it no longer wants to boot! No chime except after a PRAM reset, won't boot from hard drive or optical drive. I was able to partially boot an OS9 disc only once, but it gave me a memory error and hung. I've tried swapping the RAM around or just running one module at a time with no success. My hunch is it finally needs a re-cap after 24 years or it's a CPU issue.
The heatsink doesn't feel as snug since the G4 upgrade, very likely because the original chip had a gasket/shim around the edge that sat flush against the heatsink and it's missing from the new CPU so it's very easy to wiggle even with the tension clip on.
