IIsi logic board questions (capacitors and J19)
dv-
IIsi has visibly swollen capacitors so I ordered some replacements. I got the little square tantalum ones because I read they don’t leak. I double checked the markings and supposedly they are 47uf 16v, which should match what’s on the board.
Installed the first one, powered it on, and it exploded. Wondering what I might have done wrong.
Also, I’m wondering what the J19 connector on the logic board (by the floppy drive) is for? Tech manual only says not to touch it.
You might have reversed the polarity. Tantulums mark positive, not negative.
If the polarity is correct, there's a possibly that it was overheated during the install process though that does take quite a bit to do. 10+ seconds of continuous soldering iron contact, I'd say.
Yes, you are far from alone here. The decision to mark the other end on tantalums from electrolytics was ... not, perhaps, entirely sensible.
