Ooh, excellent update! I'm glad you found the jumper! So that was the problem as far as that goes. I was a little worried because I wasn't sure if the IIsi even had a ROM select jumper (I figured that maybe if there's ROM soldered, there's no way to use the SIMM.) Glad I was wrong, and that's awesome that you actually got it to chime!
It will be interesting to see what happens once you disconnect the motherboard RAM! Is removing VCC enough? Sometimes chips can still get phantom power over the other wires -- I've seen it on smaller chips, no idea about how RAM chips behave in that case. Maybe you could disconnect the output enable lines and/or chip select lines instead? Just a thought.
Why did the stock IIfx ROM work when the modified one didn't? Theoretically they should behave exactly the same if you have burned a standard IIfx ROM image on the modified SIMM (I'm assuming you're talking about the socketed SIMM you bought from me). Does the socketed SIMM still work in the IIfx?
