I picked up this IIci yesterday after seeing it listed on ebay for local pickup.
Drove 300km to actually get it. The listing had one photo with the case opened and something that was not a cache card was sitting in the cache slot - obviously a Turbo 040 right there. }
I jumped right on it and got it even though it does not seem to turn on according to the seller. Could only be either cap, the trickle voltage issue with the PSU or both.
First things first, the case is in a pretty nice condition. Little yellowing and no scuffs or marks on the outside. All four rubber feets on there as well.
It did not turn on as the seller stated so I took it apart and found the caps to be gone obviously. I measured the PSU and 5V trickle is there, so lets deal with the caps first.
Together with the dust that built up over time things did not look very pretty on the inside:
Some trace rot was visible right away. Removed all caps and gave the board a soapy bath.
I buzzed all traces that looked sketchy and found two broken ones. One was obvious already from just looking at it. Also heavy rot on the edge and under one of those resistor packs.
Fixed:
On the other end of the board near the power on circuit there was heavy rotting going on as well. Removed two 74s that did not look very healthy. Indeed they were not as they fell into pieces when removing them:
I ordered two new 74hc132s to replace the broken ones and put on new caps already. Waiting for them to arrive now to actually see if the board works at all.
The most interesting thing about the machine was of course the Daystar Turbo 040 that I spotted on the pictures of the listing:
Seems to be a 40MHz model judging by the 20MHz oscillator but only has a 33MHz 040 in it. Didn’t know Daystars accelerators were factory overclocked.
As an extra the Mac had a Radius PrecisionColor 24XP in it. Nothing special and probably is going to be replaced by something with at least two DSPs
It is going to get Ethernet and an ATTO SEIV along with a fast drive for some ultimate 040-powered System 6 fun.
But first I am going to have to wait for the 74s I ordered to get this little thing running at all.
The long term plan may be to put the Daystar into my SE/30 in case some adapter magic happens in the future
Fixed:
