ibook wont connect to my dlink 2310
i have the lime ibook running but it will not connect to my dlink 2310.
1 even turned off the security for a while?
how do you know the airport card is working?
i have went through the setting nothing helps?
yes i went in and made sue the airport was selected and even turned off all the security on my dlink router. nothing .
how can you tell if the airport card is working?
yes i got the at in the menu bar grayed out.
i know it is not connected
it acts like is is trying to connect and then sayed that it can not connect
my dlink does not show up in thew list of networks
should it be set to any thing special?
Before you give up, check the simple things: Is the card securely seated? Is the antenna connector actually plugged into the card? I've run into several cases where the connector was a bit loose. It looked ok, but wasn't.
Make sure that the Airport on/off option is set to on.
Reinstall the Airport software, just in case it got mangled somehow along the way.
question: what OS are you running? what about you d-link? is it set to work with 802.11b? or is is a/g only? A lot of times, a poorly configured router can cause it not to be picked up, mainly because someone sets it to support the faster speeds, and drop the slower 11b standard.
good news the problem is not my airport card. :b&w:
I am posting from it right now!
so the problem is my dlink router. I wonder what is wrong with it
well i will deal wth that latter I am very pleased right now!! [:P] ]'>
