iBook power supply model number
Hi everybody,
 I have just bought an iBook, model number M6497, without a power supply. The seller said he believed it was a 600MHz G3.
I'd like to know the model number of the power supply so that I can go look for one.
On the back of the iBook in awful grey on white (I think I need glasses), it is rated 24Vdc and 1.785A max.
Can anyone help?
Thanks,
aa
This is what you're looking for:
https://www.ebay.com/itm/382352196381
Though you'll need to get one that has the correct wall cord as this particular auction has the standard US plug included.  You can also use the older M7332 "Yo-Yo" adapter, though you have to make sure you get the later version with the smaller plug as the original version of that part number was for the Clamshell iBooks.
