I just love my iBook SE (366 Clamshell).
however, the battery seems to be completly dead.
The iBook was running OS X, so i installed Mac OS 9 to run the Battery Reset application.
Battery Reset appears to be doing something. The power connection glows orange (charging).
The battery does seem to gain charge however...
Starting up in Mac OS X and running coconutBattery gives the following results:
Current Battery Charge: 0 mAh
Maximum Battery Charge: 3200 mAh
Current Battery Capacity: 3200 mAh
Original Battery Capacity: -1 mAh
Is the battery completly dead? Or what is wrong with it? Should i let it charge on os 9; or doesn't that matter?
If it is dead i think i'll buy a new iBook battery, would this be a good buy?
http://cgi.benl.ebay.be/APPLE-Batterie-Ibook-M7426-M7621G-A-M6392-graphite-lime_W0QQitemZ170083274674QQihZ007QQcategoryZ25437QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
