How to make disks for a IIGS?
ADTpro does not work on MacOS7/8/9, MacADT does not work with IIgs images.
So the best way is to copy diskimages via serial connection (I have PM7300<>AppleIIgs)
and write the disks on the IIgs? Perhaps transferring smaller files (.shk) would be best?
Any ideas? thx!
Any ideas? thx!
Maybe a null modem cable and use ZTerm on the Mac side and ProTerm on the IIgs side?
Otherwise you could get an Uthernet II card for your IIgs and use AFPBridge to connect to your Power Mac file server.
