There is a boost converter with a rather large inductor. L7, C6, C3, VR1, D1 Form the boost converter. Check the Diode, and obviously C6 and C3 have to be replaced as well. Also, pull the datasheet on the linear technology boost regulator and check it against what it should be via datasheet. you will find your fault this way
I recapped a Mac Portable a few days ago but it's having power issues on the +12 volts line. All SMD caps have been replaced, the radials and axials too.
It works but not from a fully charged rebuild battery. However when I plug in the power adapter, together with the battery, it does boot.
When checking the battery level indicator under OS 6.0.8: it's full with the power brick connected, however when I unplug it, it goes to empty in 1 minute and automatically shuts down, while the main battery still has 6.5 volts on it.
In my other Mac Portable, the same battery yields at least another 2 hours, so the battery is not the issue.
When I test the +12 volts line at the FDD connector or on C3 ( 220uf 25v ) I measure only 11.6 volts, which is too low. On my other Mac portable, that's 12.05 volts.
I think this is the culprit of the problem. I have tested D1: ok, C6 and C3, VR1 are replaced, L7 checks fine for continuity.
Even with the bare board and power adapter connected, on my bench, I only get +11.6 volts on C3, which is too low.
I hope someone has encountered this problem and can pinpoint me to the solution.
