This may fit a G3 B&W, I'll have to test when I get that far.
I recently gutted my G4 Sawtooth for another project. Needing a new home for the internals, I've been thinking about building a case. Riding the coattails of bigmessowires Mini LC case, Here's what I've come up with so far.
I've drawn the entire case so far, after using the http://www.makercase.com/generator. The dimensions are loosely based on the Quadra 700.
I have to measure the ports still, but this is where I am at while planning.
I'm going to use a Pico PSU, and a ATX -> Mac conversion cable.
I would like to get a low profile PC ATI Rage 128 flashed to Mac firmware to save some space.
I will forego the CD Rom drive as I will use networking or zip disks to transfer data. If CD data is desperately needed I'll figure something out in the future.
The zip drive will be mounted where the Quadra's floppy sits. It will sit over the G4's RAM slots. The IDE hard disk will be mounted directly above it so they can share one ribbon cable.
An 80mm fan will be mounted on the back of the case, and a 120mm fan will sit against the front of the case pushing air over the heatsink and out the back.
I will wire some tact switches to the factory power board so that they can fit small buttons on the outside of the front of the case where the Quadra's were.
Since my power board already had an LED extension wired in to illuminate the apple logo on the G4 case, I'll use that wiring for the LED above the Zip drive.
I might get an IDE>CF adapter but I'm not really concerned about it yet.
The attached files have no port holes in the back yet. I might have the lines for the sides engraved as well. I was thinking more of holes in the bottom however. Not sure yet.
QuadraG41.0.zip
QuadraG41.0.zip
