Help setting up Basilisk II for System 6 (Macintosh Plus)
I'm getting lost in terms of finding the necessary files needed to set up the emulator, and then configuring it correctly. Can someone help?
Helpful link, but Basilisk can run 7, as noted above.
You're right but, in my opinion, Mini vMac works better for System 7 up to 7.1.1. With 7.5.3 and later it's better Basilisk II, which allows also to modify the screen resolution.
